bios how do I take it off student?
My bios has been changed to where I can't even change the clock time. What can I press to get it back to normal/?
You don't, and can't. The SVP is encrypted on the EC (which is its on a dedicated ATMEL chip with dedicated firmware) and cannot be broken like the old ThinkPads (XX30-390E) where shorting 2 lines or using a special tool on the ATMEL chip did the job to force it into a default state or let you clear it by resetting the security because it was disabled and assumed correct. That loophole ended with Intel Boot Guard (HSW-present, basically 2012+ is locked down) and proper BIOS signing on AMD models, or AMD PSB.
The only way to remove the password now is to replace the motherboard. Unless you can somehow completely reflash the EC without upsetting the private key set by Intel for the Lenovo BIOS or upsetting the BIOS checksum on non-PSB AMD machines/AMD PSB BIOS private key not much can be done now. It's on the EC NVRAM, which can't be reset by force like the older BIOSes. Lenovo pulled off the equivalent of the North Korea border on these newer machines and the storage of the BIOS password. It’s no longer an easy bypass for those who know how.
Okay then how do I get all my data and stuff off the laptop now that it will no longer turn on? How do I take the hard drive out and put it in another laptop or something?
Open it up and remove the drive, put it in a drive caddy or other machine. Here is the hardware maintenance manual, check page 53
https://download.lenovo.com/ibmdl/pub/pc...
killshot88 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 149
