Repair guides and disassembly information for the 14-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2442.
Moving parts inside the base
I recently bought a refurbished MacBook Pro 2021, and when I turn it over, it sounds like something heavy falls inside the device. The same thing happens when it's turned the right way up again. Since I got it refurbished, I don't have a warranty, so what's the best thing for me to do here? Thanks!
I would take the bottom cover off to see if what’s loose spills out, then take a picture and post it here so we can see it to hopefully identify what it is.
I've had a look, turn out the battery wasn't secured with enough adhesive so it's a little loose in the casing - is that likely to cause an issue?
Thanks!
@danhill38556 - A loose battery cell would be a thump sound.
@danj Yep, that's the sound it makes - with the cover off it visibly moves away from the housing. (Specifically the cells on either side)
@danhill38556 - If this is the same system from your other question I would just return it.
@danj It is, I think I may have to, this seems like it's not worth trying to deal with myself. Thanks for your quick responses, I really appreciate the help.
Dan Hill crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 90
