A2116 / 2019 / 3.6 GHz quad-core i3, 3.0 GHz 6-core i5, or 3.2 GHz 6-core i7 processor. Released March 19, 2019.
Advice on replacing hard drive on this unit
I have taken this iMac to peices and confirmed that it has a 1TB 2.5" sata drive as well as a 32GB blade drive - so I assume these are working together to make a fusion drive.
Now that I have taken it to peices I am inclined to get a new nvme drive + adaptor and then reinstall on that drive.
Is that a sensible idea? I suppose the other options are just putting in a 2.5" SSD drive, or putting in a blade drive (That works without an adaptor) but the nvme drive + adaptor seems slightly more cost effective and also means I can easily access that drive in a caddy if needed.
Which leads me on to my next question - seeing as the process of putting this imac back together is quite long, is there anything I should do with the nvme drive before I install it? In the past I have had situations where I install drive and its not picked up so I have to remove it again and initialize or format the drive.
I just dont want to be in a situation where I put everything together and then the drive isnt recognised!
I appreciate any help or advice you guys can offer me.
I prefer the pin compatible SSD's either an Apple or OWC are my recommendations. The M.2 SSD's with the adapter have had their issues!
thanks appreciate the feedback. Do you have recommendation for a good place to purchase one of these? Also are there any caddies that you would recommend and is it best to format the drive before installing it?
@davids355 - Getting a real Apple drive I go here Beets Tech or you can get an OWC driver here on iFixit iMac Intel 21.5" (Mid 2017-2019, Select Models) Blade SSD Upgrade Bundle or directly from OWC.
Thanks Dan, when I look up OWC I see there are also some potential issues with those drives - importantly it says a firmware update must be installed before they will work. Seeing as I have the imac in peices already I guess this would mean putting in the old drive, putting everything back together, installing macOS, updating firmware then taking it all apart again to install the new drive. As such I think i will look at either the Apple drive, or possibly just a standard SSD (I am just concious of the costs involved with Apple drive, caddy etc and wondering if the performance will be worth the additional cost vs just a 2.5" SSD drive.
@davids355 - Well… that maybe a issue if you already have High Sierra on your system. If not, you will need to have a bootable external drive setup with the needed OS installer. Then you can boot-up the system using it and install the OS onto the newly installed drive.
David Silvester crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 103
