Repair and disassembly information for the 2020 refresh of the MacBook Air model A2179 with an Intel processor that was released in March 2020.
Replaced battery but get “Battery is not charging” when plugged in
Hi there,
My inel MacBook Air was not powering on, so I just finished replacing the battery. It now power is on, but when plugged in is not charging.
If I click on the battery at the top, I can see a message “battery is not charging” even though it is plugged into power. Luckily, I have several MacBooks in the house, so I know the power supply and cables that I am using are not the problem.
I have tried to reset the SMC, but this does not seem to have fixed it. Is there anything else that must be done when replacing the battery? The only other thing I have read that may be the issue is the power board, which will be my next step.
Thanks in advance
Let’s not run the system too long (or sleep mode) as you don’t want to loose the battery’s charge.
First off I would run the onboard diagnostics to see if anything pops. Restart your system and press the D key to enter.
Next I would install this gem of an App CoconutBattery take a snapshot of the apps main window and post it here so we can see it. Make sure the MagSafe charger is plugged in when you do.
Dwayne King crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 45
