Repair guides and disassembly information for the 14-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2442.
Why is the MBP 14" not turning on?
Hey everyone, I've got a MacBook Pro 14" M2 from 2021 that was running smoothly until recently. Now, it won't boot up no matter what I try – I've checked the power cable, the charger, and held down the Touch ID button. Frustrated, I decided to open it up and disconnect the battery, and that seemed to do the trick. However, here's the catch: I have to repeat this process every morning because it refuses to boot again.
I've experimented with leaving it charged and turned off, but nothing seems to change. It's almost like the battery drains overnight, and then it struggles to recognize the charger or boot. Could this be related to macOS Sonoma? I've heard it has some battery consumption issues. Should I consider rolling back to Ventura, or could this be a battery-related problem? Currently, the battery is at 86% capacity with approximately 700 cycles. Any insights or suggestions would be greatly appreciated!
First, run Apple Diagnostics and Coconut Battery.
Using Apple Diagnostics
Coconut Battery
Take a snapshot on what CoconutBattery shows you and paste it here so we can see it as well.
Forgot to mention that I did run Apple Diagnostics and show no issues, will try this coconut battery and will came back with the result
Sorry for the delay posting the results of coconut battery
Alejandro Peñafiel crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 198
