Repair guides and disassembly information for the MacBook Pro 16'' released in November of 2019. Model A2141, EMC 3347.
Need some help troubleshooting liquid damaged 2019 MacBook Pro 16 inch
Bought this used liquid damaged 2019 MacBook 16 inch($50.00) , would like to learn how to properly test and fix this sort of problems. Have already taken apart and clean up the logic board and reassemble. Getting a reading on the Satechi USB-C power meter or 5.10V and 0.01A. If anyone could provide some further troubleshooting steps would be greatly appreciated.
Well. First thing is first. You're stuck on 5 Volts and drawing almost no current. Have you made sure that this isn't an issue with a bad part? I see it's back in the housing for this picture. These newer Macs can be weird about booting when some peripherals are not connected, but I would disconnect anything not vital for the Mac to boot and see if that changes anything.
Really the only things here I would consider necessary are the USB C boards (known good ones if possible), and maybe a battery (but only because these can be weird about booting when one is not connected). A display is nice as well if fans are disconnected so you can see if it's booting.
Unless you know it's a board issue already (you didn't mention any other troubleshooting steps). Where was the liquid damage you cleaned up?
Hi Alisha C
The only troubleshooting steps I have perform thus far was taking it apart and cleaning the logic board really good with 99% alcohol, I inspect visually the board, can not see anything burned or corroded. I waited 5 days before putting it back together to be sure, but the reading of the sate chi power meter is the same as it was before I took it apart, so nothing has really change on that regard. Liquid damage was water. Liquid damage was located near the usb-c ports for sure. I thought about buying new ones and getting them replaced but was wondering if there is a way to test them? maybe with a multimeter?
Macmod crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 70
