I tried to download software Ventura
I tried to download Ventura software in MacBook
Pro 15 but couldn’t boot so I shut down from option and after that trying to start with power button and not starting again .
What is the color of the MagSafe cords LED? Amber or Green.
It’s green , and showing nothing .
@gary64521 - Carefully disconnect the battery following this guide MacBook Pro 15" Retina Display Mid 2015 Battery Replacement also inspect the battery to see if it’s puffy, if it is you may need to replace it. But for now with nothing connected and the battery not connected press and hold the power button for a goo 15secs that will de-energies the logic board. Now just plug in your MagSafe charger. The system should spontaneously restart, let it fully boot up and do a clean shutdown. Now reconnect the battery and try to restart the system again, did it startup this time?
If you’re running I would encourage you to install this gem if an app CoconutBattery ost a snapshot of the Apps main window here for us to see.
Thank you Dan for your valuable advice but nothing working . Don’t know what happened to this . Really clueless what to do ?
@gary64521 - No reaction is not good😫
This sounds like a logic board issue then. Time to find someone with the tools and skills to debug the logic board.
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 71
