Hi @joaopaulo37789
Don't know that particular model but here's some information that may help.
It is for a Bosch WTW84270/0 (Ecologixx 7) tumble dryer.
Looking through the parts diagrams there are only two sensors or I think that there are two.
A Sensor NTC Item ID # 0527, part # 00170961 (supplier example only) but this seems to be a temperature sensor given the specifications and an Electrode, Moisture or Humidity sensor Item ID # 0217 part # 11018215 This supplier calls it a moisture sensor, this supplier calls it a humidity sensor and Bosch calls it an electrode.
I wonder if there's a switch closely associated with the tank but given the above examples which have different names for the same part/part number, it may not be called a sensor or even a switch.
Looking at a zoomed in image of the tank (click on image in the tank link above to zoom in) there's one image showing a lever on the side of the tank. Perhaps this latches into something in the machine to open it or to indicate that it is full, I don't know. Maybe it is stuck. Something to check perhaps. Bosch calls it a container condensed water and not a tank although the other suppliers listed above do call it a tank. Go figure (Item ID 0516 part # 00707089)
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
2
Hi @joaopaulo37789,
What is the model number of the dryer?
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
Ecologixx 7. Hope this is what You need. Thanks. :-)
crwdns2934271:0crwdnd2934271:0 joao Paulo crwdne2934271:0
I've had the issue where it is constantly saying the tank is full on the Bosch Serie 6 self cleaning condenser dryer. There is a compartment at the back of the dryer where the pump is. You can pop out the pump and there is a sensor beside it with 2 metal strips that detect the water level. Gunk gets caught between the 2 metal strips, clean that away and it solves that problem.
crwdns2934271:0crwdnd2934271:0 Michael Pickering crwdne2934271:0
