Bluetooth module where located
Where Asus Vivobook S500CA Bluetooth module located on motherboard.
My laptop not showing in settings.
and where we find Bluetooth Drivers
Hi @yousafnazir,
When you say that Bluetooth "....is not showing in Settings.", do you mean that it is not listed in Device Manager?
If you didn't mean this, then check in Device Manager to view the status of the Bluetooth adapter. Go to Device Manager → Bluetooth.
To get to Device Manager in Win 10/11, press the Win key + the x key (both together) and click on the Device Manager link.
If there is a red cross next to the Bluetooth entry, right click on the entry and click on Enable.
If there is a yellow exclamation mark next to the Bluetooth entry, right click on the entry and click on Update drivers and follow the prompts. You need to be online for this to work.
If this no Bluetooth entry, check in BIOS to see if it has been disabled there.
If there is no entry in BIOS or it is enabled there, then as Bluetooth is located on the same module card as the WiFi, perhaps the card is faulty.
Here's an image taken from this teardown video showing where it is located on the motherboard.
(click on image)
Here's a link that has Asus drivers that may also help
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 120
