The HP ProBook 450 G2 is a 15.6-inch business laptop marketed toward private and business users.
ssd usage pinned at 100 percent with 0.1Mbps/sec
ok let me start from beggining. before upgrading to a ssd i had no problems at all, then i upgraded to m.2 sata 3 ssd ( kingstone brand ) and the problem started. when booting up ( doesn't matter if plugged in or not ) there is a random chance that it does not boot up ( goes to a weird gray screen ) and after multiple hard resets it boots up to windows and there is the second problem, there is chance that pc is not responsive and after trying so hard to open task manager it says disk 100% 0.1Mbps/sec . i have tried multiple windows installs with forcefully not installing new drivers, still the same issue. when it works it works fine.
Update (11/11/23)
this is the closest photo i have found about the ssd and this a 120G one mine is 256 and
this is my ssd ( i cant remove the sticker its warranty ) i could not find any information on its speed sadly
@siaabd what exact model is your Kingston SSD?
@oldturkey03 - Kingston SMSM151S3/256G
What is the make and model of the replacement SSD as well as the original. I’m suspecting you are using the wrong SSD.
previously i did not have a ssd, it was a hdd that i have now removed.
the ssd model is kingston SMSM151S3/256G
@siaabd - This system requires a mSATA 3.0 GB/s drive are you sure this is a good drive?
@siaabd - The SSD does have the correct key (see the image I posted) but the data rate maybe too quick for your system. There are three SATA I/O speeds 1.5 Gb/s (SATA I) 3.0 Gb/s (SATA II) and 6.0 Gb/s (SATA III).
M.2 SSD's first came out with SATA II for a short window of time and then later jumped to SATA III
HP's spec sheet is a bit confusing HP ProBook 440, 450 G2 Notebook PC Specifications and the Wikipedia listing for HP's laptops only give us a clue of the date of production HP ProBook systems which is listed as 2014. So a SATA III SSD M.2 drive would be too fast for your system.
Ensure you have the correct drivers installed, and make sure the SSD or HDD is defragmented. Check for an remove any viruses, and use some compressed air to clean out the connectors on both the SSD/HDD and the computer.
SSDs don’t need defragmentation!
@danj My apologies, I meant to say HDD. Thanks for catching that.
Sia Abd crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 128
