@moefrumkin I also would opt to clean it with isopropyl alcohol as suggested by @jayeff I prefer to clean and reuse parts instead of just replacing. In my opinion it is a waste of money and resources to replace it, unless it is proven to be non-functioning.
After you cleaned the ports and the board properly, you will have to address the "vaporized" capacitor as well as the damaged appearing one. Use a capacitance meter on the larger one (C6520) to determine if it is indeed still functioning. If not, replace both of those.
Reference designator C6520 is a 2.2µF 10% 25V ceramic capacitor in a 603 package
Reference designator C6522 is a 0.1µF 10% 16V ceramic capacitor in a 0201 package
Soldering a 0201 package component is not easy and will require a magnifying source as well as good skills. Both of these components are part of the keyboard boost converter circuit for your keyboard backlight.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
3
crwdns2944067:05crwdne2944067:0
@oldturkey03 @danj @jayeff
Thank you for your advice. I cleaned the board with isopropyl alcohol and reassembled the computer. It all seems to boot now. If this is the case, do I need to take any other steps? It's not that important to me that the backlight works.
crwdns2934271:0crwdnd2934271:0 Moe Frumkin crwdne2934271:0
@aliquid if it works, it works. If you are okay with not having the keyboard backlight working, you are good to go.
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
@moefrumkin - Given the limits of two USB-C ports and needing one to charge the system
I would still opt in replacing the Port unit as corrosion damage tends to make the connections not as reliable and can create resistance & heat during charging.
crwdns2934271:0crwdnd2934271:0 Dan crwdne2934271:0
@danj What do you mean by "carrion damage"? Is there a chance that there is more damage that isn't apparent yet? Also, is there a place I can order a replacement USB-C port set?
@aliquid - Typo😕
As for the part, I've posted a link to it within my answer. It's only $20 USD!
