PS4 Disc Drive Connector broken, how do I repair it?
The previous owner had opened it up to clean it, and he broke the little part that you push down to remove the flex cable, he instead probably lifted it up in order to remove the cable. (shown in picture)
The error I'm getting when trying to update the console is the one where it says the disk drive isn't connected properly (SU-42118-6).
Is there somewhere I can buy a replacement connector, and just solder it back on, or maybe cut the ears off the flex cable, and then fixate it with some capton tape inside the connector, so it makes contact?
Otherwise, I'm guessing the Renesas replacement is the only way...
