The Xiaomi Redmi Note 8 Pro was released in August 2019 along with the Redmi Note 8 and Redmi Note 8T. The Redmi Note 8 Pro was the first smartphone featuring a 64-megapixel main camera.
My phone is not getting charged
My mobile is not getting charged
crwdns2889612:0crwdne2889612:0 7
Xiaomi Note 8 Pro phone does not charge or turn on. Why, sir?
Xiaomi Redmi Note 8 pro wasnt charging or turning on suddenly for no reason and after i replaced the charging board, it worked for 2 or 3 days before it died again and now it's just dead. I asked chatgpt how to troubleshoot and it told me to remove the battery and wait plug in the charger and wait if it showed red or grey light but it is dead and shows nothing.Please help
@ashwinrao72856 you are not giving us enough information. you need to consider to letting us know if anything happened to your phone? Did it just stop charging? what have you checked and what have you tried to fix it?
First you want to check your power supply. Make sure it has the proper voltages. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. Make sure there is no corrosion, debris etc. that prevents it from working. If none of this works, get a ammeter and see if your phone draws any amperage from the charger.
You may also have to consider replacing the battery. A depleted battery can no longer be charged. Measure the voltage on your battery connector with the charger plugged in. You should get around 4.2V If you do not get this voltage If you don't get that voltage check your flex cable coming from the charging board. Make sure it is seated properly and does not have any tears or other damage on it. Your phone has a separate charging board that could be faulty. consider replacing that.
Here is teh guide for the battery Xiaomi Redmi Note 8 Pro Battery Replacement and since iFicit does nto yet have one for the charging board, use this one
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
The phone is charging but the percentage is decreasing
@adriansama68501 start by replacing the battery.
I am using Redmi Note 8 from last 6 months but from yesterday it is not charging Please give me a solution what can I do
Redmi Note 8 pro kullanıyorsanız şarj sıkıntınız varsa öncelikle pili değiştirin. Eğer olmuyorsa, şarj flex değiştirin düzelir. Şarj almıyorsa bordlu değiştirim kolay işlemler.
Ashwin Rao crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 66
crwdns2942667:0crwdne2942667:0 2,553
