Power Cable and Battery
I have been trying to find answers for this for the last few weeks.
I have a 2017 MacBook Air with the I7 processor. I’m on my second battery and second charger cord with this computer.
The first battery died after only about 500 cycles. The new battery had 289 cycles and the full charge capacity is (mAh): 6543.
My first charger started to brown close to the MagSafe Connector. I have also noticed that when the cord gets pretty hot when I’m charging the computer. I can hold the MagSafe but it is on the verge of being too hot.
I have also noticed that the left corner computer gets warm while in use. I have taken it apart and dusted it. I have also upgraded the thermal paste. I’m wondering if it is my I/O board that is the culprit.
I do need to add, I have also reset the SMC.
Update (08/05/24)
I was wondering what part is causing the problem?
@dmclcc have you tried an original Apple Magsafe? One of the issues with the cheap aftermarket chargers is that they are always supplying full voltage (20VDC) whereas the original uses an IC that controls the power and even shuts off your Magsafe when the wattage goes high etc. From what I read in your Question and your comments, the issue right now is your charger and not your MacBook Air 13" Early 2017. Let me know if that is correct.
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
