Battery not charging at any base
Ok...so..
The battery isn't charging when at the homebase.
So...I took it to a base that I know works as I have 3 roombas with each their own charging station.
Still not charging but the roomba that goes to this base does charge.
Cleaned off the contacts - failed
Reset the roomba - done but still won't charge.
Took the battery out of the failed roomba and installed it in another one of my other roombas - battery charges. I put the battery back in the original roomba - fails - no charging.
For the hell of it I ordered another battery - failed - still won't charge.
Placed new battery in other roomba - works- battery charges.
I know it's making contact with the base because when the defective roomba moves to the charger it stops BUT the light stays green ( doesn't flash orange to indicate charging is active) The battery indicator slow flashes but then it disappears along with the green lit power button telling me no charging is happening.
I checked the contact pins and they are secure. No movement.
So...What say you guys?
I am having this same issue.
I check the connection between the battery terminal and the connection pad. The left one works, right one failed.
I took it apart and checked the pins on the circuit board, they all seemed to be fine and making good connection. I want to assume that it's the wire between the circuit board and battery terminal, but not completely certain. Can't find a schematic to help me tease the wires apart.
Yeah...I agree.
It's weird how this just started to happen in just the last week or so.
If it comes to then I'll just pull this puppy apart without a schematic and see what I find. I mean it's kinda useless if the battery don't charge unless I keep taking it out and charge it by swapping it out with one that is charged.
Hopefully there's a more simple solution but I doubt it.
Thanks for your reply.
Richard crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 492
