Released September 20, Apple's largest and most expensive 2019 smartphone features a 6.5" OLED display, a triple-lens camera system, and greatly improved battery life. Successor to the iPhone XS Max.
Occasionally flickering and green screen
Hi all, I am new to iFixit! Thanks all for wonderful question and answers!
My iPhone 11 pro max was once bited by my kid and camera over filter damaged. It may induce some water damage.
After that, the phone starts flickering and turn green.
Occaionally, the screen becomes normal (only top right corner problem). It seems tell me it is not the screen issue.
So, before I buy another screen to replace. May I know is it likely the screen problem or other hardware problem?
Thanks so much!!!
p.s. tried (1) reinstall iOS updated, (2) adjust brightness, (3) adjust autotone, etc.
Yeah that's most likely a damaged screen, get it replaced. I'd recommend you buy a soft OLED panel as that's what's close to what the factory installed on the device. Hard OLED is cheaper but the OLED panel is thicker and it's more fragile. Then there's LCD panels which I do not recommend or offer in my shop. They require more current and the connector on the board wasn't designed to have that much current flow through it, so it ends up burning the display connector on the board in some cases.
Thanks so much, it is my first time to hear about soft and hard OLED. I will do some research. Thanks.
Sam Choo crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 346
