The Rock Band Fender Stratocaster Wired Guitar is a guitar-shaped controller for the Rock Band video game franchise for Xbox 360.
Rock band 1 wired guitar will not turn on / connect.
I have a Xbox 360 wired Rockband 1 fender, it’s been 5ish years sense I last used it but I dug it out to play clone hero on, but when I plugged it wasn’t working, the light for the Xbox 360 logo on it would flash for a second and then shut off. I first tried a different break away cable end but I got the same result, I tried the classic wiggle the cable around to see if holding the cable in a specific way would make a better connection but I had no luck with that. I took the guitar apart and looked at the main board and there were these 2 capacitors that’s caps had turned a purplish black, all the other ones still had silver caps so I’m guessing that may be the problem?
I have the exact same problem let me know if you solve it please and thank you
Did you fix it yet?
I have the exact same, but only the c52 is black. I'm gonna change it and tell you if that worked
Sleepless Gamer crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 904
