Released September 20, Apple's mainstream 2019 iPhone comes with a 6.1" LCD touchscreen, dual cameras, and six available colors. Successor to the iPhone XR.
Problem connecting cpu and periphals
Hi, so i bought an Iphone 11 to change the screen and use it, but its restarting every three minutes, then I checked crash analysis and found two Missing sensor(s), sometimes its Prs0, but sometimes there's Prs0, mic2, should i try to replace them both, or what should I do? Can you help me? Thanks.
but in most times there is only Prs0
Those sensors are on different assemblies so in my opinion you're looking at replacing both the lightning port flex assembly (Prs0) and the flash/power button flex assembly (mic2). You'd definitely have to start with the charging port assembly, and since you're going to be in there anyway it doesn't make any sense not to replace the flash/power cable at the same time.
iPhone 11 Lightning Connector Assembly Replacement - iFixit Repair Guide
Manuales / Apple iPhone 11 / Power button, flash and top microphone
If you don't do them both, Murphy's law guarantees you'll have to go back in and do the other one.
Oris Koris crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 260
