Repair and disassembly information for the 2020 refresh of the MacBook Air model A2179 with an Intel processor that was released in March 2020.
Brand New MacBook Air M1 Not Charging
I just bought this brand new MacBook Air, it was sealed, and everything fresh out of the box.
Apple M1 2020 MacBook Air 13", 8GB of Ram 512GB
It says that the battery is not charging and that it needs repair, kind of weird, because it's brand new and out of the box. It stays stuck at 1%. When you remove the charging cable/adapter it shuts off instantly.
I am currently running macOS Big Sur 11.6.
Any help would be appreciated! Last resort would just be getting a refund and return the item.
I am going to preface this by stating, if you just bought this, I think returning, or exchanging is going to be your best. But if you want to go through due diligence before then, here's my theory.
This model has been in production since 2020. Even though Apple is still selling them, and/or distributing them, the units they are distributing may be old back stock rather than freshly manufactured units. Same for any other vendor selling them new. Just because they are still available via Apple doesn't mean they are currently in production.
The manufacture date on your unit, as well as the battery is already almost two years ago. Which suggests it sat around a while before getting to you. Lithium ion batteries don't like being put into long term storage, especially for years. They often fall into a a a sleep mode that kicks in for protection, but if the battery becomes too depleted it can no longer power that circuit, so it doesn't know it can wake from sleep.
It's definitely possible that your battery is stuck here. Batteries in this state can sometimes be revived, but it may not be worth it in your case. If you're super nosy, check the voltage on the battery with a multimeter. Left-most two are ground, and right-most two are Battery voltage.
This battery from Apple is rated at 11.4 Volts. If you get something close to this on the multimeter, then that's unlikely to be the issue, but I suspect you would get something substantially less.
How to fix, when “sleep mode” has been activated?
@danj0sk Best way is to just replace the battery. The first thing I would want to try is to measure what voltage the battery is outputting to check what state the battery is in to verify that this is the problem. If you get a flat zero volts, new battery is the best way to go.
You may be able to revive it using a DC power supply, but results are mixed and if you're inexperienced in dealing with batteries I wouldn't recommend trying this since batteries can be dangerous.
Genius Guy 234 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 45
crwdns2942667:0crwdne2942667:0 998
