Repair guides and disassembly information for the 14-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2442.
Can the HDMI part be replaced?
Hello, I have bought this model used and noticed the hdmi being damaged (most of the pins are broken inside, I tried bending them back and while some are fine now, others broke off or are still not in the right position). I have opened the laptop up to check the logic board and bought some HDMI ports, but they are completly different from what's on the PCB.
I have searched for a replacement online but couldn't find anything. I fear even with a replacement, the heat needed to remove it would be too much.
Offtopic: I am aware I can use USB-C to hdmi, it's just to have it in perfect conditions.
Ouch! You really don’t need the HDMI port do you?
Yes, it would be nice, but the costs of either finding someone with the skills and tools to replace it as well as access to a replacement part will be difficult! That only leaves Gulp! Replacing the logic board😣😖 which is quite expensive!
Ok, so once in a blue moon you need that HDMI port, now what? Simple, get a USB-C to HDMI adapter using one of the USB-C ports!
But make sure the pins aren’t shorting out!
@ciprianflo33831 - Copper is a bit more malleable than aluminum or steel. So while I wouldn’t over do the bend back it should survive a good dozen bends without hardship which is assuming you replaced the battery four times in its life and a few other events.
To be clear here the amount of bend I do is as little as needed and I use a plastic pick to wedge between when I need to do something to the logic board to prevent it getting power.
Unless you can learn how to solder or find a professional, no
Very late reply to this, but the question was more about finding the part to replace it, as I had difficulty finding an HDMI part that matched what Apple used.
The soldering bit is straight forward with a hot-air reflow station.
Ciprian crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 61
crwdns2942667:0crwdne2942667:0 1,215
