Repair guides, support, and troubleshooting information for the 2022 13-inch MacBook Air, featuring Apple's M2 SoC. Released on July 15th, 2022 and identified by model number A2681.
USB-C Thunderbolt does not work after spilled liquid
Hello everyone!
I have a MacBook Air M2 A2681 that got wet, after drying it the best i could, the thunderbolt ports have stopped working. How can I know if only the ports have been damaged or is it something on the motherboard? here on my country it is not easy to get a new port but i will try to get one to test.
I was able to remove them and tried to clean up with isopropyl alcohol
You can probably tell just by looking if it’s the port. Try looking with a flashlight and see if you spot any corrosion. Otherwise, you’ll want to open the machine up and see if there are any signs of liquid inside. You can remove the ports pretty easily and just see what they look like. If there’s corrosion on them, but internals look clean, probably just the port. You might even get it to work if you clean up corrosion with some isopropyl alcohol and a cotton swab. Depends on what the actual issue is. Liquid damage in the port can cause electrical damage to board components, but I have seen lots of these that are just the port itself.
Thanks for the quick response. i will open again and try to take better pictures
Victor Adrian Toledo crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 53
crwdns2942667:0crwdne2942667:0 991
