Swap SSDs between two “nearly” identical MacBook Pros?
I have two Mid-2010, an Early-2009 and a Mid-2009 MacBook Pro, all are the 17” A1297 unibody models (don’t ask…:).
One of the mid-2010 MBP is not enterely a 2010 model, some parts have been installed from a 2011 MBP (display assembly and airport card if I’m remembering right). The logic board is the original 2010 i7-620m (2.66GHz) though. The other mid-2010 MBP has i7-640m (2.8GHz) CPU.
Can I just swap the storage drive to/from the early-2009 from/to the mid-2009 MacBook Pros? Some infos: Kingston A400 SSD; already installed in one; OS X El Capitan + Windows 7 in Boot Camp.
Also, what about swapping another SSD between the two mid-2010 MacBook Pros? Infos: another Kingston A400 SSD; already installed in the 2.66GHz one; OS X High Sierra + Windows 10 “was pain the butt to set it up” in Boot Camp).
So, practically, I’d like to use one SSD for the 2009 series and another one for the 2010 series.. will it work? I don’t mind using four (or maybe 5, we’ll see…) laptops but I’d like to avoid having 4 or 5 different systems… would be difficult to keep them in sync.
Thanks in advance!
Focus on the systems SATA port standard. So a SATA III system can support older SATA I or SATA II drives. That isn’t always true the other way! So a FIXED SATA III drive won’t ratchet down it’s data flow to the slower SATA I or SATA II system! There is a small loophole to this! This is where an AUTO SENSE drive is able to auto-magically ratchet down to what the system can support.
So now locate the spec sheet for the SSD to check it’s specs then match it to what the system logic board supports:
  • 2009 - SATA II (3.0Gb/s)
  • 2010 - SATA II (3.0Gb/s)
  • 2011 - SATA III (6.0Gb/s)
So if you swapped out the 2010 logic board to a 2011 you may encounter issues moving it’s drive to the older system.
Thanks! Everything seems to be working so far.
BrianM crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 132
