Weird problems on my Alexa Echo Dot 4
Recently, my echo dot just stopped and started flashing blue suddenly again and again, for the whole night. When I woke up , I realized it was off(like absolutely off nothing was on and it wasn’t responding). I tried to reset and unplug but to no avail. Finally, I decided to open it up. After opening everything and reassembling everything it is working fine except for 3 BIG problems. Volume up button doesn’t work, the Alexa button doesn’t work, and it doesn’t respond(mic is dead). Idk how this happened. I’ve opened up a lot of tech stuff and never messed it up.
Have you checked the ribbon cable between Motherboard and control board? Did you reseat it properly? While prying did you destroy any components?
If all of these are not true, may be see the control board under a microscope and you can find if some contact of a component is not soldered properly.
Even very experienced people sometimes make mistakes. Just take a look of the FPC connectors for the ribbon cable under a microscope. Even a single bent pin would create such disconnected problem. Also check the FPC ribbon cable if there are any tears. I have damaged a Logitech G Pro Wireless cable by accident and the crack was only visible under a microscope. Fortunately you can get the replacement ribbon cables if you search properly and based on the pitch of the cable on AliExpress or eBay.
Thanks, it turns out that cable connecting the control board to motherboard wasn’t pushed in. 😂
do you know any supplier where i can find those flat cables to buy for replacement? it happens that one of them is ripped.
do you know any supplier where i can find those echo 4th gen flat cables to buy for replacement? it happens that some of them are ripped.
h_man08 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 406
