Why is there lines in my printing
There's white lines in the middle of the drawings or words that I print out
The printer head is a collection of spray nozzles. What often happens is a few get clogged so no ink is ejected so you get a line it could be a colored line or if all three base colors are blocked a white line (no ink).
Time to try cleaning the print head either via your printers programming or physically using a paper towel and some isopropyl alcohol carefully sliding the head across a flat surface
If that fails get a new printer cartridge
I've been cleaning my nozzles every week and it never fully goes away, even tried nozzle alignment, but there always seems to be either white lines if printing in black and white or washed out colors, especially yellow. It seems to print better when printing via USB on the computer which set it up, but trying to print on laptops is just a nightmare, tried looking for drivers but all I find it just bloatware from epson installing 3 same apps, from all symptoms I expect this to be driver/software issue since cleaning it barely helps and computer which connected and set up the printer seems to work the best but still causes lines especially from web base print orders.
@mantas84813 - Have you replaced the print head?
See if cleaning the prince rollers helps, over time paper dust can buildup on the rollers stopping the paper advance cleanly.
While rare the paper advance gear train maybe damaged so it has some slop.
I can’t see this as a driver or software issue.
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 116
crwdns2942667:0crwdne2942667:0 3,127
