What is error E05?
I tested almost everything in this oven, but I never had a manual or documentation for the BOV800XL /A. The thermal fuse was continuous, the transistors, triacs, variable resistors, resistors, capacitors, etc. seemed fine. I did not check the transformer or relays. Here is a link to a version of the manual that vaguely describes the errors on page 54. My continuity test showed that the old oven sensor reads at about 125 kΩ at room temperature. Other sources say it should be in the range of several thousand ohms. Any suggestions/sources for E05 error code?
@nathantafelsky E05 should be a failed Triac
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
If it read at 125kΩ then it might be a faulty sensor. A functioning oven sensor should read in the range of several thousand ohms at room temperature,
crwdns2934271:0crwdnd2934271:0 Pookie crwdne2934271:0
@oldturkey03 Both triacs had the same resistance across their anode-to-cathode, I think the triacs are fine. They don't show any signs of overheating, and current only flows in the direction it is supposed to.
crwdns2934271:0crwdnd2934271:0 Nathan Tafelsky crwdne2934271:0
