The Moto E4, also known as the Motorola Moto E 4th Generation, or model numbers XT1765, XT1766, XT1767 and XT1768 was released in June 2017.
I dropped my phone and the entire screen went black.
I received a hand me down moto a little while ago that already had a couple of cracks it it. And today I accidentally dropped it and the camera broke. And the screen also went black. I know it still works because I feel the device vibrate when I press and hold the power button. Which would indicate that it was asking me if I wanted to shut the device off. What tf do I do????
You could try (blindly) tapping the correct places on the screen, if it is still registering taps, to first enable dev mode, get into dev mode, enable usb debug, then connect to a computer and use ADB and scrcpy to render the screen on your desktop. To take this route it would help to get ahold of someone with another E4 that can take images of every step (importantly every tap and swipe with exact motions, skipping nothing), perhaps with a ruler next to the device such that you can then recreate the motions on the blank screen. Of course, thats only if it still registers taps...
Hi Rami,
While there is a small possibility the display connector has gotten disconnected as a result of the drop, it's far more likely that the fall has exacerbated the existing screen damage and put the final nails in the screen's coffin.
If it was my phone, the first thing I'd do would be to follow the screen replacement guide up through Step 5 where it shows how to disconnect the LCD connector. Unplug the connector, clean both sides with 90% or higher concentration isopropyl alcohol then reconnect it. Reassemble the phone and see if that's made any difference.
Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement - iFixit Repair Guide
If, as I suspect, it still doesn't show a picture, then you'll need to source a replacement screen and follow the guide the rest of the way through to replace the LCD. Don't forget to purchase precut screen and rear case adhesive sheets so it'll stay together when you reassemble it. Just as a tip; I usually buy a couple when I need them; they're quite inexpensive and unfortunately all too easy to mess up, so having extras on hand saves you from having to wait while you reorder if you do get them tangled up and unusable.
If your phone is the model with the fingerprint sensor let us know and we'll see if we can locate the correct guide for that phone since the guide I pointed to specifically says not to use it if your phone has the fingerprint sensor.
Good luck; let us know how it goes!
@dadibrokeit teamwork! ^_^
If you need to purchase a new screen in India, buy it from iService
you need to replace the screen
Motorola Moto E4 Screen Assembly Replacement
Moto E4 (XT1766) Screen - Genuine
crwdns2886500:0Replace a front glass digitizer panel compatible with the XT1766 Europe model Moto E4 smartphone. Features a 5.0 inch IPS LCD 720 × 1280 Display. Includes the Front Plastic and Metal Frame, Edge Bezel, Fingerprint Sensor.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$79.99
Rami Poco crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 907
