A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
mac installation fails and restarts after selecting disk
I'm trying to do a fresh macOS installation on my 2017 macbook pro but it freezes when the progress bar starts, then "your computer restarted because of a problem" message shows up and restarts. Same happens when I try to restore using time machine. Ps: I have the lcd cable disconnected.
Are you in recovery mode? You should try erasing and re formatting your disk, and then reinstalling macOS.
I have done all the above but it still fails. Could it be the usb-c hub I'm using? I tried a different yet similar hub today and it still failed.
Try changing that… It could also be a thermal issue. Make sure you have the back cover on your Mac; that acts as a heat spreader.
@ryan39167 - This series doesn’t use the case as a heat spreader/sink. If offers a proper heatsink and fan.
@chillin_otb - What happens after you connect the display back in & any other parts, minus the bottom cover. Then with the charger plugged in restart the system and pressing the D key to enter into diagnostics. Are you able to get that far and running diagnostics did you get any errors? If you did tell us what you got.
Chillin Otb crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 53
