Released January 2020, identified by model numbers SM-A015F, SM-A015F/DS, SM-A015G, SM-A015G/DS, SM-A015M, SM-A015M/DS, SM-A015T1, SM-S111DL, SM-A015V, SM-A015A
Why is the battery not charging
Phone doesn't charge
Kaileena Fullbuster first check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws and amperage from the charger. if it does not it is possible that this is a charging port issue or a bad battery. Both can be repaired
If what @oldturkey03 said did not fix it and your phone still has some battery life left go into Settings > Device Health > Scroll down to the bottom and select diagnostics > Battery Status. If your battery health is bad, you might bring it to a shop, or repair it yourself, iFixit sells lots of great kits for this type of thing (they don't sell one for the AO1 to my knowledge) it also could be a charging port issue like @oldturkey03 said and if you don't know what's causing the issue for a fact maybe bring it to a Samsung shop or your carrier if they do repairs.
@that+person4451 just a bit of advice from an old guy. Your answers are good, just remember that the goal for iFixit is to empower anyone to fix their own devices. Taking the device to a repair shop or the manufacturer for repair, should always be the absolute last option. Remember that
REPAIR IS WAR ON ENTROPY
Why not fill out your About page and tell us more about yourself?
@oldturkey03 Thank you for the advice, and will do
Charge problem
Bijoy, you haven't given us enough to go on. Explain what the phone is doing or not doing, when it started and what you've done to troubleshoot the problem.
@bijoydjbagti 2 words aew not enough to describe the issues with your phone. We need the exact model an and maker for of your phone. Next you want to tel us what you have, what you have checked and what you have tried.
Kaileena Fullbuster crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 1,671
