Repair and disassembly information for the 2020 refresh of the MacBook Air model A2179 with an Intel processor that was released in March 2020.
Broken display cable connector
After removing the display cable connector, I can no longer snap it back into place. I dont know if the connector attached to the logic bord or display is at fault. Is there anyway to tell? Do I need to purchase a new monitor?
Display
https://ibb.co/nRL6p8h
Logicboard
https://ibb.co/nwJkB9p
@allydelish, We would need better and more closeup images than the link. Use a lot of lighting, preferably a camera with macro functionality and a tripod (stand) to keep it still and a very high F-stop (aperture). The high F-stop requires a lot of light to pass through a tiny aperture, which increases the shutter speed greatly which makes it necessary to use a tripod.
Update your question with new images: Adding images to existing questions.
uploaded new images. looks like it might be the display.
@allydelish, It looks like you got the text describing the images backwards? Logic board connector <-> Display connector.
The connector on the logic board looks destroyed, as in will not allow the display to “snap” in. You’ll have two options:
  1. If you have the micro soldering skills and tools, you can replace the connector yourself
  2. Contact a reputable micro soldering shop in your area and pay them to replace the connector for you.
The job of replacing the connector is not a first time DIY job! It requires skill and a lot of fairly expensive tools in order to do it. Hot air rework station, appropriate solder and flux, replacement connector(s), microscope, ++.
crwdns2944067:07crwdne2944067:0:
Just to make sure, Are you talking about this image : https://ibb.co/nRL6p8h
This is the closeup of the display. The one with the letters & numbers is on the logicboard.
@allydelish Yes, that’s the one, just me misreading and being a little tired :s
The cable on image https://ibb.co/nwJkB9p is removable. Its a picture of this: MacBook Air 13" (Late 2018-Late 2020) Display Cable|Shopping|SSC|Parts|tROAS390}&pk_source=google&pk_medium=cpc&pk_kwd=&gclid=CjwKCAiAleOeBhBdEiwAfgmXfzabITom8ea6kRULRPa7WGBmMotaMKHNeMZZde6PN8S8Iuc6p8p4oRoCDRwQAvD_BwE
I removed it and took a picture. I was going to replace the cable, but thought Id ask first.
@geirandersen Can you send me a link for the part that would need to be soldered on.
@allydelish If you could find your logic board number, I’ll see what I can find. It’s printed on the logic board itself
crwdns2934275:02crwdne2934275:0
Ally crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 110
