A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
Very loud fan after battery replacement
I replaced the battery for my Mac last night and let it charge for a several hours afterward as directed. When I first tried to power it on nothing happened, but after holding down the power button enough times it eventually turned on. It seemed to be working fine with no lagging or anything except the fan was on really loud and wouldn't turn off. I unplugged it with the display open to see what would happen and it just shut off and wouldn't turn on again until this morning. Now it seems to be functioning again but the fan is still really loud even though the device isn't overheating. I also can't see the battery icon in the upper corner so I downloaded coconutbattery and all the numbers (current charge, charge capacity, etc.) say 0. Looking at other posts on here it sounds like maybe I messed up the trackpad connection to the logic board? Or could this indicate that I damaged the logic board itself somehow? Thank you!
edit: added coconutbattery info
Let’s get a better view of things install this gem of an app CoconutBattery take a snapshot of the main window with the battery tab opened up and post it here for us to see.
Hi, I posted the screenshot from coconutbattery above. It says power adapter not connected but it actually is and the device only turns on when the adapter is connected. Does that give any helpful info? Thanks
@caden h - this is a bad battery ☹️
Basically. The Batteries micro-controller is not working. You’ll need a new battery.
hi can i post my screenshots too?
@ana37661 - Best to create your own Question. Then you can tell us your details and see your images.
Well this video might be helpful for you: https://www.youtube.com/watch?v=mFrCGmW7...
caden h crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 482
