2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
Internal keyboard not working after battery change
Hi guys
First time posting here, thank you all in advance! So I recently changed the battery on my 2015 Macbook Pro.
Upon booting up the machine, the built in keyboard is no longer working.
Trackpad works 100% fine, power button works fine and keyboard is backlit OK.
Re-opened the machine and it appears that the keyboard connector is bedded properly with the latch closed.
I've seen some posts that suggest checking for software updates etc, but I don't think this is the case.
Also seen some posts saying that the keyboard connects to the motherboard VIA the trackpad, something I don't fully understand if there's a connection which seems to go direct from keyboard to motherboard.
Any help or suggestions on how to fix this would be very much appreciated!
Thanks
J
Update (01/06/2023)
Thanks for that advice! I've just taken some screenshots. Using wireless keyboard and trackpad.
I'm not really sure what it means! Any further help gratefully appreciated.
Apple over the years have altered how the keyboard and trackpads connect to the logic board. Some series have discrete connections whereas others daisy chain keyboard to trackpad to then logic board.
So don’t get to lost on what the others do focus in on how yours works. In your system each connect to the logic board independently via separate cables as you can see in this guide on Steps 27 and 33 MacBook Pro 15" Retina Display Mid 2015 Logic Board Replacement
So here it’s likely the cable is not squarely inserted.
Thanks for this. I've checked multiple times and I'm really sure that the cable is inserted properly. If this is true, what would you advise as the next step?
@jacksonlapes - mmm… While the cable connections are discrete, both electrically connect to a common internal USB hub.
Using an external keyboard & mouse, go to the About This Mac and click on the System Report to check the USB hub and what is showing up.
@danj Thank you so much. I've just added some screenshots in a reply below, couldn't post an image in this reply section!
@jacksonlapes - Well the driver is working so that only leaves the the touchpad cable which is messing up the keyboard data (shorted to ground).
Time to replace it MacBook Pro 15" Retina (Mid 2015) Trackpad Cable
Thanks Dan. I'm going to get that part ordered now.
Did it fix it? I ordered a new cable, it worked for the first time and because of the fans, I took it out and put it back in. It stopped working. Any idea?
Jackson Lapes crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 151
