Blinking Power LED 1 Long White 4 Short Ember
I have a Dell Inspiron 14 3000 (Service Tag 91T5S53)
I have been getting a constant Blinking Power LED (1 long white and 4 short ember) I cant seem to find the error code online.
The computer works fine with the power plugged in no issues, but when unplugged turns off immediately, which I thought indicated a battery replacement. I replaced the battery and nothing changed, I still get the same flashing power LED.
The replacement battery is recognized in Windows with a 55% charged capacity but doesn't charge any further nor does it discharge.
I tried uninstalling the Microsoft ACPI-Compliant Control device driver in Device Manager and restarted the computer, but that failed to fix the issue as well.
I have ran the offline Dell Diagnostic several times but comes back with no errors.
I also ran the Dell Support Assist in Windows, and comes back with no errors as well.
There are no BIOS updates as I have applied all available critical and recommended updates.
Can anyone explain what the issue could possibly be and how to fix it?
Hello, how was the problem solved? I have the same problem.
Hi,
Create a battery report to check the status of the battery.
When you have the report, compare the Design Capacity value versus the Full Charge Capacity value. For a good battery they should nearly be the same.
As far as I could find out a 1 long white, 4 short amber blink error code in Dell laptops means a bad battery.
You may just have got a bad replacement.
That's usually it with Dell, frankly. The color was amber before Skylake when they went to the white LED, but kept the pattern.
Jafric Rhyner (Rasjahshout) crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,112
