Repair guides and support for videocassette recorders including Betamax and VHS (Video Home System) players.
HR-S7000u replacement head and service manual.
Doe anyone know where I can find a replacement heads or upper video drum for HR-S7000U seems like parts are hard to come by and parts units are over $200 for a possible good part!
Update (12/17/2022)
Ii did the same thing been looking for weeks for the manual found the HR-S7000EU it was a different beast all together here a shot of the drum
Did you ever get the service manual?
Did you ever find the HR-S7000U service manual online?
No, I found a manual for HR-S8000U since they share the same transport I was able to align my S7000u and order a replacement head.
Hi @stereo068
Here are the drum sub assembly and the upper drum assembly (supplier example only) for the recorder.
The part numbers are JVC LP20617-008A and LP20030-015A respectively.
Here's the service manual for the recorder. The chassis and mechanical parts list is on p.26-27.
Search online using the part number only to maybe find other suppliers. i didn't look too hard ;-) As you said there's not much out there but maybe you can find either a used S7800U/U(C), HR-S2110T or S6700KR recorder at a reasonable price and use that as a parts donor.
crwdns2944067:07crwdne2944067:0:
Thank you Jay ! The manual is for S7800 it's completely different than the S7000U I'm working on the Upper Drum is also different the original part has JVCH73V0 and PDM3017 and is 4 heads most places show it as 2 heads .
@stereo068
OK
I was only going by the title on the manual where it says S87000U/U(C) as shown in the link I posted.
This is what shows for a PDM3017 which doesn't sound like a drum part
Ii did the same thing been looking for weeks for the manual found the HR-S7000EU it was a different beast all together here a shot of the drum[image|2818865
@stereo068
Do you think that this may be an option to consider?
Depending on shipping of course. Bit of a gamble I know
That's a S7100U completely different the HR-S7000U is a front loading SVHS machine and the parts machines are over $200 at that point its more than it's worth as I was hoping it will work with a simple height adjustment without the test tape and scope!
crwdns2934275:02crwdne2934275:0
Marlin K crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 273
