An update to HTC's original Vive, now with improved displays, sensors, and ergonomics. Released April 5, 2018.
Will your Vive Pro Headphone replacement part fit the Vive Pro2?
Hi, I have a Vive Pro 2 Headset and the left earphone is failing [sound stops playing on the left side]. Will your replacement part [Item # IF453-028-1 HTC Vive Pro Headphones] fit the Vive Pro 2 headset?
I have already removed the left earphone and verified that the contacts are clean. The sound is intermittent. I need a replacement part for the left earphone that has the volume control button.
Has anyone successfully used these replacement headphones on a Vive Pro 2 Headset?
Thank you,
Edward
Hey, Edward.
As long as you're capable of doing it yourself, I'd say it's fine to use a Vive Pro Headphone replacement on the Vive Pro-2. There is not too much differentiation between the two headphone parts, and certainly not enough difference to cause an issue. I hope you find this helpful.
Edward Leslie crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 172
