There are various different renditions of Saeco Minute coffee machines, also under the brand name Philips. All types start their Type Number with HD8xxx. Here you see a Philips HD8834.
Where does the two pipes go from the water pump.
My coffee machine is tripping the earth all the time when making coffee and when I opened it, I saw two water pipes leaving the pump, one of them (clear one) is not connected to anywhere and tip is lying loose in the machine. Is this normal ?
See Saeco Minuto Pumpe tauschen, step 16. The pump ist connected top two pipes, one in (the clear one) and one out.
Thank you. I meant the two pipes exiting the pump. One of them seems to be not connected to anywhere. I wonder if it is a pressure valve and the distal end is juts free/loose into the tray.
@Alp Numanoglu : can you take a photo? Adding images to an existing question
Alp Numanoglu crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 160
