A netbook from Asus's Eee PC line with a 10" display and an Intel Atom processor. Released in 2010.
Does anyone happen to know the power connector dimensions/specs?
I got an Eee PC 1015 PN from my employer (they were getting rid of them) but it came without a power adapter. I do have a power supply capable of supplying the proper voltage and current so I only need to find a matching connector to hook the two together.
However I struggle to find any mention anywhere online of the physical dimensions of that connector. Asus mentions them neither on their site nor in their user manual and every time I risk a web search I must swim through countless power adapter replacement ads which of course never mention it either.
I could not find a service manual of any kind either. T_T
If anyone had any information about it, I'd be forever thankful to them for sharing it. ;)
Update: I have since stumbled on a power adapter selling site which claims that the dimensions of the jack are 2.315mm x 1mm however since I have not been able to find any connector with those dimensions I am hesitant to trust those numbers.
(link: https://www.ibuybattery.com/laptop-power...)
Hi @nekoniaow,
Okay, I found an Amazon page for a supply for your netbook that lists a different size for that connector.
Amazon.com: Power4Laptops DC Adapter Laptop Car Charger Compatible with Asus Eee PC 1015PN-PU17-WT : Electronics
According to that listing, here's the size of the plug you need.
  • Plug Size: 2.5mm X 0.7mm
Those plugs were pretty easy to find; here's one of the first I ran into.
uxcell 5Pcs DC Male Connector 2.5mm x 0.7mm Power Cable Jack Adapter Black - - Amazon.com
Hopefully that's more what you were looking for.
Oh, interesting. This definitely seems more standard than the dimensions I found.
I will give it a try, thanks.
Asus laptops tend to be fairly universal, to the point you can use a common adapter; I have even test fit Toshiba branded ones on them and it takes; the exception is the thin-and-lights like the ZenBook series.
Any good quality 3rd party adapter like the Targus universal will work, essentially. That said, I still recommend a OEM Asus but if you want a good 3rd party universal it usually isn't an issue.
The Asus EEE PC 1015PN uses an AC adapter that has the following specs.
Input: 100-240V (Worldwide)
Output: 19V 2.1A
Power: 40W
I was able to find a replacement charger here, but I always recommend shopping around because you might find it cheaper on eBay.
Thanks but I already know those numbers, my question is about the physical dimensions of the connector, not about the electrical specs since I already have a power supply and only need the proper connector to plug into the computer.
Nekoniaow crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 469
