Can I install a battery from a newer unibody?
Being my battery is slowly dying, i need a battery soon
Can i get one for a late 2009 and up unibody 17''?
just to clarify, i have a early 2009 unit, i would prefer to install a mid or late 2009 battery if it's possible, maybe a early 2010
Up until late 2008 they used the same battery but in early 2009 they went to a bigger built-in battery. So if your MBP is a 2008 or older I would say the answer is no. Early battery is a MA458 68w unit--later battery is a 95w built in unit. Hope this helps.
I was aware it's built in, i am wonering if i can get a late 2009 and up battery and get more mAh hours out of the computer
Hi,
have you tired installing the newer battery yet?
I did it yesterday without even knowing and only found this thread today.
I went from the 73 Ah to the 77,6Ah version on a MBP 2009 / 2,66 GHZ and everything works fine so I suppose it migt also work on a 17"
BR
!BATTA!
My 2009 17" had a motherboard failure :-(. Fan controller went belly up, and a SMD resistor came loose.
Nick crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 603
