@beanman56 - I would leverage a known good keyboard to trace out the which pins within the connector are shorted.
Remember, the keyboard is a simple X - Y grid. What makes is tough is locating the active horizontal and vertical lines effected as its not a simple 7 H by ~14 V line matrix.
oldturkey03 had placed the connector pinouts here, not sure why he took it away as you need it to reference the lines. I'll need to dig out a better diagram as the one within this systems schematics is not very good
Its been awhile since I've needed to debug a keyboard issue. Often its the keyboard its self or the ribbon cable connection to the logic board.
Rarely do I find a single line damaged. Here you have a single vertical line misbehaving (5 - T - G - B) not sure why you also have [ - ? effected as well I don't think they are within the same line.
My money is on a bad keyboard (spill or other junk) I would first replace it or the uppercase assembly.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
0
@beanman 56 The B,G,T,5 issue appear to be a keyboard issue not a logic board issue.
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
Never mind, I found it.
820-3115-B
crwdns2934271:0crwdnd2934271:0 Ben Capehart crwdne2934271:0
@beanman56 you said you have a broken pin in the connector, that means you know which line is the one for your B,G,T,5 issue. Let us know which one it is and replace your connector. That way it is fixed and will work for you again, You are the one with the answer:-)
