My phone fell and the display stopped working.
My a70 fell on the ground and my display turned black with green lines, i did a soft reboot and after a while the screen started working, the display touch, AOD, everything. But its black with green lines again, is the cable disconnected or do i need a new display?
Update (09/30/2022)
I fixed it it was a loose connector i just pressed onto the back of the phone, for others looking for solutions above the samsung logo on the back is where to press
Thanks a lot for sharing. It worked for me too
I fixed it it was a loose connector i just pressed onto the back of the phone, for others looking for solutions above the samsung logo on the back is where to press. Actually it worked once then did the same blacking out process, and now after massaging the back of the phone its working normally so probably was a loose connector, because if it was broken it wouldnt turn on at all. Also its an amoled display not an lcd. Thanks though.
Thanks for sharing. It worked for me too. God bless you
It could be the LCD panel is broken, and you would need a new screen. I believe if the cable was loose or disconnected, the screen would be 100% black.
No Problem. I am used to LCD so my bad.
Damjan crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,399
