Intermittent horizontal lines bottom 3rd of screen fix
This is a 58” Vizio smart tv model V585-H1
I’ve had this tv for a few years and about 2 months ago I lost my picture entirely and deduced I had to replace the tcon board. I did this myself and it was a great success.
Just yesterday I’ve encountered a new problem: horizontal lines on the bottom of screen that come and go. 14 seconds of lines, 10 seconds of no lines. Repeats, with little variation. I timed it. Occasionally the lines cover about half the screen, but only briefly.
Coincidentally, my kid spilled some Koolaid behind the tv and the problem showed up a couple hours later. I’m reluctant to believe that this has anything to do with the tv problem because I don’t think any of the drink actually got into the tv. I’m not entirely sure though.
I’m tempted to just replace the tcon board again and see if that helps, but since it’s not the same problem as last time (and I just replaced it) I’m not sure if that will do the trick this time.
I would really like some insight as to what I should do to try to fix this issue myself. I’ve posted pictures of the with lines and without lines.
Update (09/26/2022)
I’ve tried:
Power cycling
Changing the picture
Cleaning and reseating the ribbon cables
Factory reset
I’ve inspected all the boards carefully and see nothing that appears damaged.
smacking the tv
Hoping someone can point me in the right direction here
@hnovitski your TV is running into issues with the Gate drivers. These IC’s are mounted on a flexible cable(s) which are bonded to the LCD panel. Their function is to activate each row of pixels. they are coming of the LCD driver board. That is the board where the flat ribbon cables from the T-con/Main Board connect to. Since there is no data or schematics readily available for this, it'll be very difficult to fix. Take a look at the thin ribbon cables (DO NOT TRY TO REMOVE) on the LCD panel and see if you find any corrosion, loose cables etc. Sometimes just pushing against the cables will make a difference.
Of course check all the interconnect cables for any corrosion or tears. Make sure they are all seated properly etc.
I think you’re right, I was just hoping it was something else, that I could actually fix or replace myself. I did look at those ribbons carefully but didn’t see anything amiss, except for 1 on the end where the ribbon looks a little like it got pinched on one small area. I probably did it myself from removing/replacing the panel cover, I’m not sure if that’s the problem or not.
Tomorrow I’m going to mess around with it while it’s plugged in with a picture on the screen and see if I can manipulate something to get rid of the lines. If that fails, I might try the tape trick I see floating around. That seems like it might be a quick and dirty fix for something like this. I guess I’ll see.
I did the tape trick to get from a black screen to good picture, with one caveat: there appears to be an intermittent faint white light blinking behind the right edge of the screen about 3 inches down from the top. It is brightest at that spot, with a bit of brightening across the upper-right area of the screen. It blinks on and off about every second, but is faint so only a bit distracting but it doesn’t obscure the image on screen.
slo-mo, up close
Here is a video of the blinking on mine…
@bernieschmitt that does not look like a driver issue. That looks more of a backlight issue. What model is your Vizio?
Thanks for the note! It’s also a V585-H1. I think it also makes faint lines, will try to remember to get a close-up video
Close-up “slo-mo” attached/added with the other video
Is it safe to say the tv is done for ? I had this M55-D0 for 7 years
@mikejones75010 nope. not yet. It aint dead until we all determine that it is, based on the information we need, to tell you that it is dead. You forgot to tell us what is wrong with it? What does, or does it not, do? what have you checked? TV's don't come with expiration dates, yet :-)
While leaving TV on and back still off; take an old pencil better new bc it needs to be with an eraser that's not gotten old and hard yet. Hold the pencil with eraser side down and tap each component even capacitors and connections with the eraser barely. If lines stop for split second while on a certain component then replace or fix that component. You will have to have someone on the other side of TV to look at screen for you or put it in front of a big mirror. Just to make sure if it's the t-con again or not , bc you don't want to waist money if it's another board.
Henry Novitski crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 2,562
