MacBook Air with hi-speed fans and pfm006 ppn001 message
Hi everyone,
all of a sudden yesterday my Macbook Air 13" I5 started having loud fans and being a bit jittery.
This is what I did:
- reset PRAM and SNC
- cleaned system cache
- cleaned login elements
- rebooted in recovery mode and checked disk (HD was not mounted) >
- managed to mount HD and run repair, after that volumes looked all ok
- run diagnostics and then it gives pmf006 and ppn001 (plus ppt002 - low life battery) messages
No spillage has happened, nothing stranger than usual.
Logic board was changed by Apple in Dec. 2021
By running Acitvity Monitor the CPU load lies at max 60% (mainly kernel_task) and the temperature is 42/43°C...
macOs is Mojave 10.14.6
I am scratching my head. Anyone has some suggestions on what could be the issue here and how to fix it? I'd be extremely appreciative of any hint or tips!
Update (09/16/2022)
Thanks a lot Dan...here are the screenshots from both apps
Any idea?
Thanks indeed...
crwdns2944067:06crwdne2944067:0
Given the systems age I'm suspecting the battery is just worn-out.
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see.
I've often seen this with bad battery thermal sensor. You could also install TG Po and post a snapshot of it as well.
crwdns2934271:0crwdnd2934271:0 Dan crwdne2934271:0
@djoker27 - I spun off your question I’m having lots of errors! Diag codes PPT002, PFM006, PPN001.
Marti - @process_gone did you try replacing the battery? Did it solve your issue? I have exactly the same issue and similar MBA, been banging my head at different posts on internet. Would appreciate your response.
crwdns2934271:0crwdnd2934271:0 Manuj crwdne2934271:0
Martina Bertoni - I moved your question to its own space - Battery & diagnostics errors as well as high kernal_task process
I am having the same issue and same diag codes 2017 MacBook Pro. Did changing new battery worked out for you guys? Went into Apple yesterday and it cost $400 to replace the battery so ordered one on eBay to replace it myself.
crwdns2934271:0crwdnd2934271:0 Cocologo crwdne2934271:0
