Are the batteries of a MacBook Pro and MacBook Air interchangable?
Could I swap in a Macbook Air SSD into my MBP?
This suggests I can, but I'm not sure if that's just an aggregate link.
Hi
As far as I know this can be done in certain cases but you have to be careful
If you are swapping a ssd that has been confirmed to work
If the ifixit listing says you can,it should work as ifixit is quite good at part compatibility
If you are ordering outside of ifixit I would ask the seller
Hopefully this helps
Any questions please ask
You are asking two questions here:
1 - Are the batteries interchangeable - The answer is no they are not
2 - Can you swap the SSD between the systems - Might - Might not!
The series between the systems has a bearing here Apple altered the drive types a few times as such you can't use the older drive in the newer systems or the other way. In addition the very newest retina models don't offer removable storage.
Here's a bit more to help you on ID'ing the different SSD's The Ultimate Guide to Apple’s Proprietary SSDs
crwdns2942667:0crwdne2942667:0 94
