Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
Charge discharging when charging and drains the battery completly dry
i changed my charging port in my iphone 3gs and the phone works perfectly but when i tried to charge my phone my phones battery gets discharging slowly, but my phone is being detected by itunes, HELP ME
I have this problem to . at first it was working fine and this started i tried to charge 47% and when i came back it was 12%
crwdns2933315:010crwdne2933315:0
Stalone,
Your symptoms have me guessing 2 things.
1: Something is not connected or reassembled correctly, possibly causing a short and resulting in the discharging that you are describing.
2: It's possible that your charging fuse is blown (possibly caused by a short?)
Disassemble your phone again and reassemble, being especially mindful of any contacts that may touch the frame or case that shouldn't. While you're in there, check your fuses. See oldturkey's answer for fuse location.
crwdns2944067:010crwdne2944067:0:
i did checked the charging fuse but still the battery is discharging and i replaced the charging dock too , the phone is in charging but the battery discharges while charging..
Did you check your assembly too for any possible shorts like I mentioned? How is the phone still running if you can't charge it? Are you able to charge it when the phone is off?
i took my battery out and charged it with a battery charger n then i assembled my phone and tried to charge it.
have you tried a new charging port/dock??
yes changed a new charging port, nothing works . now trying to change the battery
crwdns2934275:05crwdne2934275:0
I have this similar problem with my Samsung s5...I have tried all means it couldn't work not until 1day that I charged it with the back cover removed...till now (going to 3months) I didn't experience such problems again
Please help me, I am charging my phone and it is just discharging. It discharge from 22% to 0%. Am using Techno W3
I think i have the Same problem with ms 3GS 32GB. I wanted to charge my iPhone and when i connected it with the dock-cable it makes a short "beep" and the display gets dark. My repair-service has changed the battery 4 times and also the dock-connector. It don't charge. I tryed another service and they told me: the logicboard is broken. ( the fuses are o.k., i checked them )
And finally the said: there some non-origin Apple-Parts build in. We don't fix it. Because of the warrenty. Warrenty? For a 3,5 Year old iPhone? I'm not interested in a,I want a working phone.
But that's another story....
I have same problem with my Iphone 5, after water damage I opened and cleaned the main board, everything is working but it is discharging while charging. when I plugged in the charger iphone shows Lightning symbol like it is charging but in fact, percentage goes down.
Tried to replace Battery and Dock connector - but didnt help.
Anyone know what on board can be the reason for this?
Thank you.!
Did you solve this problem? I have the same problem now with iphone 5. It charges 1 out of 5 times. Tomas.
I'm having the same problem! My s3 got water damaged but I'm not sure if thats anything to do with the problem but its charging really slowly and the battery pecentage go down even when charging and it stays on the same pecentage for ages . It only charges fully when I don't touch or use the phone. This same problem happened before a few months ago but I stopped charging it for a few days and used a universal charger and I even tried a new usb cable and battery they didn't work. But after Using the universal charger for about a week I used a decent charger my brother had for his Plus 1 phone and it started working again. But the problems came back and its not the cable or battery I've even cleaned the port. :( I can't return it back because I've had it for months and it has no warranty
I have this problem too. Maybe it's an issue with the dock because the iPhone charges when I plug into my computer.
Update (04/04/2016)
I changed the part that plugs into the wall -problem solved.
Hi Morriskinuthia,
I'm not a technician and am responding based on my experience. You could change your charger and see if that works. Perhaps something in the cable or port is not connecting as it should. Try someone else's charger before you get a new one for yourself.
To fix this issue - 1) change your port or entire charger 2) do not charge any other device in your phone charger. Other devices may cause your charger to overheat and burn the fuse in the port. That's when your phone starts discharging. N.B. I lost a couple of ports so I k
Maybe your cable is bad. Change it as well and make sure not to charge any other devices using your port in the future.
i think its because is acting like an ass'
On that tecno g9 discharge issue, I have 100% solution to it and you still the ideal
For any other phone that have the same problem of discharging while charging it.
It happened to me too, all I did took the Battery out and back again after few minutes and it started charging
stalone marshall crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 51,046
