Repair guides, support, and troubleshooting information for MacBook Air models with 13-inch displays.
crwdns2934591:03665crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Will My Bent Display Lid Corner Cause Further Problems?
I dropped my M1 Macbook Air on the ground, as it was open, face-down. The right corner is now bent outwards, and I was wondering if this is simply cosmetic or if it will cause issues with the screen or anything over time.
So far, the only issues are that there is a slight yellow discoloration in the corner of my screen, and it takes a slight push of a finger to get it to close all the way as it wants to close just enough to sleep.
Hi Haley,
I'm afraid it's a moot point as to whether the bent case will cause problems for the LCD or touch screen.
You see, on MacBook Air models, the display is all fused together, so it's basically unrepairable, meaning you can't just replace the case, or the LCD, or the digitizer individually; the only thing you can ever do is replace the whole display as one piece.
In other words, you can't do anything about it whether it will cause problems or not; the only solution is to replace the whole thing. It may or may not give you problems down the road, so your choices come down to either living with it as is until and unless it breaks further, or replace the whole thing, which isn't a cheap thing to do.
You can get all the parts and a guide to doing the repair yourself right here on iFixit; you mentioned it's the M1 model, so my best guess is that these would be the part and guide you need to do the repair.
MacBook Air 13" (A2337, Late 2020) Display Assembly - iFixit Store
MacBook Air 13" Late 2020 Screen Replacement - iFixit Repair Guide
crwdns2886500:0MacBook Air 13" (A2337, Late 2020) Display Assemblycrwdne2886500:0
crwdns2934075:0crwdne2934075:0
$399.99
crwdns2944067:011crwdne2944067:0:
Ah, okay. Thank you for your input. I think I will continue to use my computer as is until I notice any issues down the road.
@hbrook
Just to add to the amazing answer from @dadibrokeit
My 2014 MacBook pro has the same thing and I seriously recommend not touching any when around the bent area as once they are bent it takes next to no force to crack the as display sadly I know from experience ;-{
@hellomacos Oh man. Okay, thank you for the advice.
@hbrook
Also if you want to help the display sit closer safely I recommend loosening the hinge to give it some more wiggle room
That what I did and It helped it close a lot:-)
@hellomacos oh thank you! I was wondering if I could even fix that issue cause that's what I was really worried with.
crwdns2934275:06crwdne2934275:0
Haley crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 736
