Model Number A1707. Released June 2017, this MacBook Pro features Kaby Lake processors up to the 2.8 GHz quad-core Intel Core i7 processor with Turbo Boost up to 3.8 GHz.
Loose USB-C Ports 2017 MacBook Pro
I have a mid 2017 Macbook Pro and all of my USB-C ports are loose (do not click when cable is inserted), have been to my local Microcenter and they say that I would have to replace the entire top case, and cost around $180 plus ~4 week wait time. So, I am wondering if there is any other way to fix this issue.
Well, I'm not sure why they told you that! The case is not where the connectors are. Here's the needed part MacBook Pro Retina (A1706 & A1707 Late 2016-2017) USB-C Board now the grounding clips are springs which sit in slots as you can see here
You'll need to pull the logic board out to gain access to the screws which hold the Port assembly and/or access the springs. Now if they have snapped then you will need a new case assembly unless you can find a junker to steal them from it. Here's the guide MacBook Pro 15" Touch Bar 2017 Logic Board Replacement
crwdns2886500:0Replace one of the thunderbolt connector boards from the left or right side of your laptop.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$21.99
Thank you so much
@can_of_bread - Happy fixing!
I am just seeing this answer as my Macbook Pro 2017 2-Thunderbolt Ports (A1708) USB-C ports are causing my usb-C hub to disconnect at the slightest breath. I've tried cleaning the ports and the problem did not improve. This answer shows the board for the model with the Touchbar from the same year but mine does not have that. Do I need different parts or process? Please share! Of course would prefer an easier fix to keep the connection solid, but anything helps! Thanks.
Stephen Syvertson crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 70
crwdns2942667:0crwdne2942667:0 4,589
