The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
SATA ODD connectors used for HDD/SSD
Hi everyone,
Can I use SATA on board for Optical drives for HDD/SSD ? And it’s same speed (SATA3) like on HDD connectors?
Thanks a lot.
Update (05/13/2022)
@oldturkey03 no I know that PATA and SATA are totally different, but on my board are two SATA connections ODD_SATA (Optical Disc Drive?) how you can see on attached picture (blue IDE , red SATA). So my question is, can I connect HDD/SDD on this two connectors ?
  1. Not sure if someone still using CD/DVD :)
  2. Need more space :)
crwdns2944067:04crwdne2944067:0
The onboard SATA ports in this older series is SATA II (3.0 Gb/s) which requires a SATA II drive, most SATA III (6.0 Gb/s) won't run correctly if you use one on these ports.
Installing a PCI board which offers SATA III ports would be a better direction if you need SATA III ports.
I was thinking about that but all PCIe are currently used.
@roboscrap - Then your only option is to install larger drives for your available ports hopefully SATA III.
If you are thinking SSD then going with a Samsung EVO/PRO drive will work as its one of the few drives that auto sense the systems SATA I/O and matches to it! So it will work on your SATA II ports.
@danj all SATA ports are SATA II / SATA3GBs and it's look like this will work (on ODD SATA connections). but thanks anyway :)
@roboscrap your optical drive should actually be a Parallel ATA (PATA), originally AT Attachment, also known as ATA or IDE interface. It maxed out at 133MB/s. It will not have the speed that your SATA 3 drives have. Not compatible interfaces (connections). Let us know the exact year for your Mac Pro
Update (05/13/2022)
Yes you can use those ports. Remember that the 2006 - 2012 Mac Pros never saw internal SATA3 so you are tight to that speed on those connections
@oldturkey03 you are right, my Mac have originally PATA ( I didn’t see this for decade :D ) so what you saying is that the PATA and SATA connectors using same chip ? And both have 133mb/s ?
@roboscrap no what I was saying is that the IDE interface maxed out at 133MB/s whereas the SATA 3 is at 6GB/s. Those are different interfaces and they are NOT compatible, sorry about confusing you ;-)
@oldturkey03 thanks a lot, I mean SATA3 = SATA3GB not SATA III :)
@roboscrap :-) got it. Yes, those are all SATA 2 :-))
Rob crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 751
