Vertical lines middle screen Samsung 65au7105
Greetings to all community.
I have an issue, with a new Samsung au7105 tv. It has 2 vertical thin lines at the middle of the screen. Is there a way that i could fix this?What are the causes and possible solutions?
Thanks in advance, all help is welcome.
Update (05/11/2022)
Greetings jayeff,
thank you for your answer.
I would say they are 2 thin coloured lines side by side and in the middle between the 2 lines is black.
I bought it new in an auction of delivered electronic items, but with no warranty, like those Amazon returned items .
Since it has no warranty my option is to find help so i can try to fix it myself.
Is there a way i can post some pictures? I am new here.
Thanks again for your answer.
Feedback and possible solutions would be highly appreciated.
@iamike post some pictures of what your screen shows with your QUESTION. That way we can see what you see. There is a difference in lines so it'll help us to help you. Adding images to an existing question
Thanks oldturkey03,
I think I did already, all help is welcome.
Kind Regards
Hi @iamike
Are the vertical lines black or coloured?
If black it could be a loose tab cable connection to the screen. These connections are very fragile and if they lift off you will get a black vertical line, in line with where they've become disconnected.
If they are coloured then the driver board for the particular colour pixels in the line i.e. red, blue or green is stuck in the on position. If white then all 3 colours are on.
As it is a "new" TV, check if the manufacturer's warranty period (usually 1 year) is still valid and if so get it repaired/replaced under warranty. Do not attempt to open the TV to see what's wrong as this will void the warranty.
Update (05/12/2022)
Hi @iamike
See the link in the comment posted directly below your question to see how to add more images to your question (they can't be posted in a comment)
Although to me its looking like a cable connection problem, corroded or loose.
Here are two videos that may help.
The first shows the connections between the tcon board and the boards that connects to the screen via the cables that I mentioned
The second shows the other side of the boards (not that you can see the cables connected to the screen that well but hopefully you get the idea and will be able to see better if you have to go that far. read the comments under the video #2 as I agree, don't use hot glue to try and stick that loose cable back down. It may cause more problems than what you already have.
Be safety aware when working in the back of the TV and disconnect/remove the power when actually disassembling etc. You don't need more problems. As always with electronics, be gentle and take your time ;-)
video 1 video 2
crwdns2942205:01crwdne2942205:0:
Greetings,
Thank you for the prompt responde.
Were you able to see the pictures i posted?
I will have a look at the videos this evening, hopefully i am able to fix it myself.
Thank You very much
Mike crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 194
