2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
crwdns2934591:0773crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Black screen, power on chime, no external video
  • I have the startup chime & laptop powers up
  • Do not see icons by shining light on screen
  • Brightness all the way up
  • Twice the screen came up for 2 minutes, then went black
  • I have done the PRAM/NVRAM & SMC reset many times
  • I have re-seated the video cable to logic board
  • I have removed & re-connected hard drive
  • If the power is low I see the low-battery flashing indicator on screen
  • Connect HDMI to external monitor does not work
What happens when you press the D key do you enter into diagnostics?
Reference: Mac startup key combinations
Thank you for responding, same blank/black screen.
- Tried holding down D and starting up: I hear the chime but screen stays black
- Pressed & held D after chime....same result as above
Well, that not good ;-{ Your logic board has issues within the PCH logic. You'll need a new logic board. Depending on which you have it will be the Intergraded (IG) or Discreet Graphics (DG). These are the low end models:
Here's the guide: MacBook Pro 15" Retina Display Mid 2015 Logic Board Replacement
crwdns2886500:0MacBook Pro 15" Retina (Mid 2015, Dual Graphics) 2.5 GHz Logic Boardcrwdne2886500:0
crwdns2934075:0crwdne2934075:0
$349.99
crwdns2886500:0MacBook Pro 15" Retina (Mid 2015, Integrated Graphics) 2.5 GHz 16 GB RAM Logic Boardcrwdne2886500:0
$299.99
RedCorvette crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 461
