circuit within battery? what for?
Can I use a normal battery for mobile (3.7v) in the jbl micro wireless? The original battery has a transistor (or whatever) together. If so, what would change in the functionalities?
Sadly you’ll need to get the proper Lithium Ion battery for your device, you can’t use just any battery.
The device which you identified on the battery is a thermal sensor to monitor the temp when the battery is being charged so the battery is not over charged.
For now (will check), THANKYU!!! So, can I use a normal mobile battery and “just” NEVER leave it charging while playing? Or playing while charging, naturelik Second question! As is said in Brasil; “good will is there to be used!”, cheers good will man ,not the slapping bad (and false) one! He wouldn't know that.
@Teji Osdali - Not that simple! It's not a use Vs charge its charge alone. Nor just use any battery, it must be the battery the unit was designed to use.
Just get the correct battery and if you need to transfer the sensor to the new battery (the correct battery for your device).
Thanks again! I'll see what I'll do.. Still wanting to use a bigger mobile battery that I already have and fits perfectly in the case. Transfer the sensor sounds good, thanks!
Teji Osdali crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 152
