Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
crwdns2934591:0552crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Replaced battery 2 months ago, battery not recognised and system slow
Hi there,
I replaced the battery 2 months ago. the laptop was working fine. Out of the blue my laptop is not recognising the battery both in system report and cocunutbattery (see screenshot).
As soon as i disconnect the magsafe the laptop immediately shuts down.
Reset the SMC a couple of times, wiped PRAM, updated to the mac os - still no luck.
Sadly the batteries onboard micro-controller has failed you’ll need to speak with the seller to get a replacement battery.
hey Arun Kumar, you should check the motherboard for something arround the battery area, it maybe the connector or something , well i have seen a problem like this before (not on mac btw) on a yt channel by some technican , he tried to fix some “throwed-away” laptop and one of them is same as your problem , this was cause by some small part inside the motherboard that was broken .
if this didnt help you out then u can search some yt video
Arun Kumar crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 38
